vcVector
A 4x1 column vector which is generally used to define joint lengths in robots, offsets and directions, and angles of rotation.
Referenced by: vcBoundingBox.Center, vcBoundingBox.HalfDiagonal, vcBufferProductsStatement.PatternStep, vcCamera.CenterOfInterest, ... (see more)
vcCamera.Eye
vcCollisionRecord.PointA
vcCollisionRecord.PointB
vcDirectionalLight.Direction
vcFrameKinematicData.AngularVelocity
vcFrameKinematicData.LinearVelocity
vcLineSet.Lines
vcLineSet.getLine()
vcMatrix.A
vcMatrix.AxisAngle
vcMatrix.Euler
vcMatrix.N
vcMatrix.O
vcMatrix.P
vcMatrix.Quaternion
vcMatrix.WPR
vcNavAgent.PathCorners
vcNavMeshData.AreaBoundaries
vcNavMeshData.DetailedMeshVertices
vcNavMeshData.MeshVertices
vcNavMeshData.TesselationVertices
vcNode.localToWorld()
vcNode.worldToLocal()
vcPointLight.Position
vcPointSet.getPointPosition()
vcProductTypeAssemblyPatternItem.DefaultBoundsDimensions
vcSnapService.TargetNormal
vcSnapService.TargetPosition
vcSpotLight.Direction
vcSpotLight.Position
vcText2DSet.Position
vcToolFrame.Inertia
vcTopology.getPoint()
vcTopologyPickService.TargetNormal
vcTopologyPickService.TargetPosition
vcTransportPatternInStatement.PatternCount
vcTransportPatternInStatement.PatternStep
vcTriangleSet.Points
vcTriangleSet.getPoint()
vcTriangleSet.getPointNormals()
vcTriangleSet.getPointPositions()
vcTriangleSet.getTriangleNormal()
vcVectorEnumProperty.Value
vcVectorExpressionProperty.CalculatedValue
vcVectorListProperty.Value
vcVectorProperty.Value
vcVectorStepProperty.AllowedValues
vcVectorStepProperty.DefaultValue
vcVectorStepProperty.Value
vcVolumeDetector.Corner1
vcVolumeDetector.Corner2
| Values | list[Real] | R | Gets vector values as a list of 4 reals. |
| W | Real | RW | Gets or sets the w-component (fourth element) of vector. |
| X | Real | RW | Gets or sets the x-component (first element) of vector. |
| Y | Real | RW | Gets or sets the y-component (second element) of vector. |
| Z | Real | RW | Gets or sets the z-component (third element) of vector. |
| angle | Real | vcVector vector | Returns the angle between vector and a given vector, in radians.See moreParameters: vector (vcVector): a vector to calculate the angle to Returns: Real: angle between the vectors |
| angleDeg | Real | vcVector vector | Returns the angle between vector and a given vector, in degrees.See moreParameters: vector (vcVector): a vector to calculate the angle to Returns: Real: angle between the vectors |
| cross | vcVector | vcVector vector | Returns the cross product of this vector with another vector.See moreParameters: vector (vcVector): The other vector. Returns: vcVector: Cross product of vectors. |
| dot | Real | vcVector vector | Returns the dot product of this vector with another vector.See moreParameters: vector (vcVector): The other vector. Returns: Real: Dot product of vectors. |
| getQuaternionAngle | vcVector | vcVector vector | Returns the angle between vector and a given vector, as a quaternion.See moreParameters: vector (vcVector): a vector to calculate the angle to Returns: vcVector: a quaternion representing the angle between vectors |
| length | Real | None | Returns the magnitude (length) of vector. Returns: Real: magnitude (length) of vector. |
| new | vcVector | None | Creates a new vector with values initialized to (0, 0, 0, 1). Returns: vcVector: Created vector. |
| new | vcVector | Real x, Real y, Real z | Creates a new vector with given values, initializing W-component to 1.See moreParameters: x (Real): X-component of the vector. y (Real): Y-component of the vector. z (Real): Z-component of the vector. Returns: vcVector: Created vector. |
| new | vcVector | Real x, Real y, Real z, Real w | Creates a new vector with given values.See moreParameters: x (Real): X-component of the vector. y (Real): Y-component of the vector. z (Real): Z-component of the vector. w (Real): W-component of the vector. Returns: vcVector: Created vector. |
| new | vcVector | vcVector vec | Creates a copy of the given vector.See moreParameters: copy (vcVector): The vector to create copy from. Returns: vcVector: Created vector. |
| normalize | None | None | Normalizes vector. |
| square | Real | None | Returns the square of vector. Returns: Real: square of vector. |
| toString | String | Optional Keyword[includeW = Boolean], Optional Keyword[precision = Integer], Optional Keyword[includeZeros = Boolean] | Returns string representation of matrix.See moreParameters: format (vcMatrixFormat): The representation format. precision (Integer): Precision of real values. includeZeros (Boolean): Include zeros up to the defined precision limit. (P=45.000000 vs P=45). |
